1 - 19 of 19 Posts
I just got my car back from the body shop due to a front end accident. When I got it back the Speedo/Trip gauge cluster wont light up at all when you turn the headlights on. I am totally puzzled as to what the problem is. I check all relative fuses and they are fine. I even replaced them just to be certain.
Any ideas or fixes for this as i am driving in pure interior darkness at night.
I searched the forums and didn't find anything. I appologize if this has been posted before.
Thanks!
BGS
Body shop is denying responsability for this problem as well. Claim they never came near any of that wiring.
Is the little knob to the left of the steering column turned all the way to the right (i think)? Figured it wouldn't hurt to make sure.
It is turned all the way to the right. I usually keep it as dim as possible but it producing no light at all.
You checked ALL of the fuses in the engine bay as well? I've had this issue before and it turned out to be a fuse you wouldn't expect. My issue was none of my dash lights were coming on.
Which fuse was it?? I will double check those engine bay fuses again.
The "Brake", "Cruise", "Check Engine" etc all come on though.
Boobs!? WHERE!?!
Alright bud I'm here. There are a couple of things I'm gonna need you to check. Is the entire cluster out? You said the only thing that doesn't work is the gauge cluster lighting right? You checked the dimmer switch to make sure it was connected and works properly right? Now the all important question... DOES ANYTHING ELSE NOT work in your vehicle? Does your light under the center console work? Alright, if all is good, I'm going to need to remove your cluster to get a good look behind it. To remove it, you have to first pop off the plastic console. It's held down by a couple of pop rivets. After that, remove the four screws holding your center concole down. Finally, disconnect the three connectors on your cluster. I need you to look at the circuit board on the back. Of the cluster. I had a problem a long time ago with mine... There was a small piece of it that actually burned through the IC board over time and broke the circuit. Take a good look at that and, if it's only like one piece of your cluster out, check the light bulbs. The bulbs are encase in small holders that can be removed with an easy twist couterclockwise. If you haven't fixed it yet, let me know and we'll go deeper.
Discussion Starter · #13 ·
The only thing that lights up in the vehicle are the dome lights, and then on the safety system lighting.
The night time illumination function is tweaked. I checked the dimmer last night, it appears all well. I also check the back of the cluster and it appeared fine. I'll re look at it again since i did it a night under a single light.
Ill be back later tonight to tell what I have done today as well.
Discussion Starter · #14 ·
did your air bag deploy? if so... they were doing things in that area, and you need to take it back, and get it fixed.
Air bags didn't deploy. I honestly don't know if my SRS system even works seeing how many electrical system problems Ive been having with this car.
Boobs!? WHERE!?!
Wait you checked the dimmer? How could that be if your domelight is that only thing working? How about your radio? Is that functioning correctly?
Discussion Starter · #16 ·
http://www.club3g.com/forum/problem-reports/124769-dash-lights-out-after-tinkering-w-radio.html
That was my issue. I think it was my daytime running lights fuse or whatever they are called (turn signals). Just check all of the 10-15 amp fuses just to be sure.
It was from the blown fuses! I looked at my parking lights and the body shoped ripped the wiring out of the lighting so it made contact with the car and popped both fuses. Everything is working fine now since I replaced them.
Didn't think the parking lights affected the interior illumination system.
Titanium Spork
they have the same controller. glad to hear you rare good to go.
I was right for once? Sweet.
1 - 19 of 19 Posts
