Lower end noise is never good.
1.Yes, if one is bad it could literally mean all are bad. I'm thinking the noise problem is coming from a journal on the crank that got welded with a bearing, but that could be a small part in a larger problem.i figured as much. im thinking the slight crank pully wobble could be from a spun main as well...
although someone mentioned a thrust bearing, think that could cause the clunk and wobble?
