I have a 2003 mitsubishi Eclipse GTS Auto Sportshift. I have had a 3" racing exhaust and a cold air intake for a few years. I had my license suspended and din't drive my car for a while ~1year. I started her here and there, moved her around a bit. Had it in storage. I pulled it out like 3-4 months ago, change fluids. I was driving it with no problems for about a month. Then, as the weather got a little colder in the Fall, I noticed that when it was colder, after sitting overnight, I'd start the car and it would hesitate to start for a little bit then fire up. And if I shut it off and start it again within a few hours, it started up no hesitation. However if I would leave it without starting it for like 8 hours or more, it would hesitate the first time I start it. I had a valve cover gasket leak. Needed to do plugs and wires too. So since I had to take my intake off, I tore it apart, ordered valve cover gaskets (front and back) an upper intake manifold gasket, new spark plug wires, 6 Bosch Platinum IR Fusion spark plugs, and a new air filer for the CAI I had. So I replaced all of that and got that taken care of. While I already had a project going I decided to fix my front suspension by getting new strut and spring assemblies and sway bar links (Unrelated). But point is, after all that work, I started driving her again. First time I started it up, it idled a little high, but it settled itself out now. I drove it fine a couple days, then noticed it was doing the same thing, but worse :-( After sitting overnight, or more than 8 hours, the first time I start it, it seems like it's choking, struggling to start. I barely see the needle spike past 500 RPM, and it dies after like 5 seconds of an attempt. Then if I turn the key again, starts up just fine. And it continues to start just fine if I shut it off and start it again within just a few hours. But outside of that, I have trouble. Now I had this problem before the work I did, so I know it's not directly related to something I forgot. But just in case, I made sure I didn't forget any vacuum lines or anything when reassembling the intake.
Better yet... Get this... I always have my check engine light on due to my illegal exhaust, oops. But I've always been able to scan for codes periodically. And before I ever even let the car sit in storage, it stopped working. The module won't even power on when connected to my obdII port. :dunno:
I'm going to start with some sensor replacements. But any ideas would help. I feel like we're not gunna luck out for much longer with no snow. So I want to try and get this targeted quick as possible.
Just my opinion do not start putting anymore money into sensors or anything. That's aimlessly throwing away money. I mean if the sensors arent bad and you buy new ones, you just threw away money. Now with the obd scan. Have you tried wiggling the the plug? I lnow that sounds simple but thats a possibility with that situation. Lastly AIR,FUEL,SPARK, what are you not getting? Also check your throttle position sensor and idle air control connections. Hope this helps.
Thanks for the input on the OBD port. I'll check that soon as I can and see if that resolves it. As far as air fuel and spark, I seem to be getting all. I double check to see if my fuel pump was engaging properly after sitting. On the first turn without starting it I can hear it power. So idk. I just installed a new air filter with an electric fan on it though, so that's new. But it's definitely sucking a lot of air. It's certainly audible when driving. All six seem to be firing just fine. And I have those brand new wires and plugs. It almost acts like it may be flooded after sitting. It runs beautifully otherwise. Once I get it started it really behaves flawless. One thing I noticed now is my purge valve solenoid is clicking bad. I will probably have to replace hat now. If I can't figure out that issue with it starting I might focus on the OBD port to see what codes it's throwing, that might clue me in. I definitely appreciate any and all feedback though.
