1 - 2 of 2 Posts
Sorry In advance if this has been covered before but I couldn't find anything specific. I have an 03 2.4 gs manual trans... I came he from work one night and my dimmer switch was broken so I couldn't cut off my lights I was exhausted so I just figured I'd jump it off in the morning... Long story short it's never started again. I burned the starter up trying so I replaced it. My fuel pump isn't engaging so I checked and it works and I am getting no fire to the coils the code reader threw an immobilizer code at first but now says cannot connect. The starter turns over but nothing else and this car has had no other issues since I have owned it the last year.... Thanks for any help.
Super Moderator
It sounds to me like you may have some trouble in your wiring harness... If you got it hot enough to burn out the starter, this would likely be the case. You do not mention replacing the dimmer switch... If you have not, maybe that is causing a dead short?
1 - 2 of 2 Posts
