Your car hasn't blown up yet? It sure will if you try what you just said.
Sure, happy to help. I do have one question that wasn't clear in your first post. Ripps current stage 1 setup has the stock injectors in place with the supplemental injectors adding fuel during boost. It seems like you have replaced the stock injectors with bigger ones and are about to engage the supplementals. Is that the case? I don't think that will work well with the current tune of the BB and BRAT. You end up running rich and whacking out your LTFTs. Meaning idle will suck and cruise will suffer. Keep the stockers in place if you plan to use the stage 1 setup as is.Thank you guys for advice
I can't do that for you over the forums. You need to be able to log your LTFTs and then do this process:Can you help me to scale the current bigger injectors that I have with the ECU flash? If you are busy I understand
Yeah, but every once in awhile I mellow out. However, I think I'm done at this point.Phil, aren't you getting tired of repeating yourself? You go harder on the n00bs over on the org than here. :lol:
