So I have this problem with my '01 Eclipse Spyder GS. After 5 minutes or so of driving and oil starts to warm up, Temp. Gauge starts reaching 3/4's on the dash. It's stays there when moving above 30 mph but doesn't come close to reaching the H for overheating. Then when i start to slow down and come to a stop at a light, Temp. Gauge comes back down to normal right to the middle. When I start to move again, gauge climbs back up to 2/3's-3/4's and stays there. I've put in new coolant, replaced the upper and lower hoses, and the thermostat. Planning on getting a new radiator cap and a funnel to burp the cooling system to see if I have any air in there.
Also no white smoke coming out of the exhaust.
If anyone has had this issue on there car and found a fix, or can give any info as to why my car is doing this I would greatly appreciate it.
Ok this happen too me about 3 months ago.. same exact symptoms. . The problem is.. you need to burp out you're radiator. . The way I burp it out was I bought a spill free funnel here's the link of what it is
Lisle 24610 Spill-Free Funnel:Amazon:Automotive
the reason you're car is doing this is cause you have air inside of you're radiator. . You need to take the air out..
On my car the reason.. air was getting in was cuz I had a hole in my coolant reservoir. . But yeah.. check out some youtube videos on spill free funnel to learn more about it.. good luck man..
Thanks, just ordered it yesterday as well with the radiator cap. Hopefully it gets here by wednesday so I can check an see if that is the problem.
