Well, I have a 2005 GT Spyder with 93k and NO signs of a cracking dash, and should note that I have stock rubber motor mounts, not urethane.
Other members have expressed theories on why the dash is prone to cracking on these cars, but in reality it's probably a multi-pronged problem with various factors in play.
I think most would agree that the problem starts with quality control, that is, the use of cheap materials during production. I have no clue if Mitsu used different dashes for different years and/or trim. Some have suggested that using stiffer urethane motor mounts contributes to cracking, but it seems to affect the 4cyl more than the 6cyl due to differences in engine vibration. I have a set of prothane mounts waiting to be installed, but I am wary they will induce dash cracking, even though I have the v6.
I would imagine that not having a garage would add to the probability of cracking, especially extreme changes in temperature and direct sunlight. Personally, my driveway is oriented so that I can park without ever having the windshield in direct sunlight, at the expense of having some fading of the inside trim below the rear window.
So someone who keeps their car stored in a climate controlled space probably has fewer chances of cracking.
Then another factor is which cleaner/protectant to use on the dash. So far, I have only heard that Armour-All should be AVOIDED, but have no idea which one might be best for the Eclipse in particular based on the material used for the dash. I typically use Macquire's products, but have heard good things about 301.
Anyway, hopefully others will chime in on what they do to prevent or minimize dash cracking.
