· Registered
Hello people, I currently have halogen projector depo headlights and really want to retrofit the not so good projectors for some valeos. I think I pretty know how to do this project. The only thing that I'm not sure of is the wiring as far as getting both the hids and the original depo high-beams to work as usual. Do u get me? If I do my low-beams the only plug that goes from the headlight to the car's harness would be that of the low-beam hid and the old depo male plug with the high beam cord would sit there useless... How can i connect the high beam to the hid harness so that everythings in perfect working order? :dunno:
Thanks in advance
· Super Moderator
:lol: what? no offense but if you cant figure out how to wire up your headlights then maybe you should leave this to a professional? highs goto highs and lows trigger hid ballasts...like in any other normal HID setup.
anything else, you'll need an extra relay to keep the HID low's powered when the high beams are on. someone here sells the high+low relay all put together for you, plug and play.
