1 - 3 of 3 Posts
I drove my 3g this am like any other morning. I set my cruise control after about 15 min of driving, neutral flashed at me and I couldn’t get into gear at all. Parked it went through some basic checks, nothing seemed too out of place. Any guidance would be appreciated.
Super Moderator
Disconnect your battery for an hour. There is no information on your profile...Is this manual or automatic.
Per the factory service manual:
A/T DIAGNOSTIC TROUBLE CODE DIAGNOSIS CHECK "N" RANGE LIGHT <VEHICLES WITH SPORT MODE>
The "N" range light flashes once per second if there is an abnormality in any of the items in the table below which are
related to the A/T system. Check for diagnostic trouble codes if the "N" range light is flashing once per second.
Input shaft speed sensor
Output shaft speed sensor
Each solenoid valve
Gear incorrect ratio
A/T control relay system
CAUTION
If the "N" range light is flashing twice per second, it means that the A/T fluid temperature is too high. Stop the vehicle
in a safe place and wait until the "N" range light switches off.
1 - 3 of 3 Posts
