i have a 2000 eclipse gs with damaged trans.
my 4th gear is broken so instead of going 1,2,3,4,5... i need to go 1,2,3,5.(still able to be driven fine)
i need to buy a used trans and the labor is gunna be $400
it also needs all new tires + an allignment
i got the car for $2,800...
is it worth fixing or should i sell it and if it is worth keeping what order should i fix things in.
Administrator
Well, you're looking at another $1,000 for on top of what you bought the car for to get it running decently. Make sure the timing belt, drive belts, and all other misc. maintenance has been done too. Once you figure up the cost, figure out if it's worth it to you.
yea its just that im gunna need a new bumper cover and trans and tires/allignment so i need to know if it's worth it, if something breaks that small like a belt along the way with it ill fix it then but for the 3 big ticket items is it worth keeping??
