1 - 20 of 26 Posts
I'm looking for a twin turbo kit for my 2000 eclipse gt. Does anyone know where i can buy a kit or do i have to make a custom one? Has anyone made their own twin turbo kit for there eclipse and is it worth putting twin turbos on? Thanks!
Lubisz To Suko!
just search a couple months back someone was selling a twin turbo kit with the engine and the whole nine, i dont know how it turned out tho, also there's a member from Canada with a twin turbo
Never say never!
gt_02 said:
Twin turbo? dream on...
I wouldnt say that! Anything is possiblle and it has already been done. Although I would say its probably not easy to do. Unless your willing to spend alot of money and do alot of research you would be best off just going with a single turbo setup. Even then you have to do alot of research and have lots of GREEN! Make sure you check out the forced induction section!:bigthumb:
It's a 6G72, the 3000GT VR4 was a 6G72, the big difference is that the VR4 was DOHC and built for boost, mostly you would just need to build up the internals, a y pipe off the tb going to 2 different side mounts(much better cooling that FMIC), then to each turbo ran off each manifold. I highly recomend just going with a small to medium turbo on each manifold, since it produces more power and is better in the long run than one running off the other turbo.
Everyone always forgets about RPW as well. Check out www.rpw.com.au and find their price list (top of the page, towards the right side, click that, then scroll down a bit and click on "RPW National / International Pricing Schedule", and then once you get the .pdf file that has the price list, find the section for the SOHC 6G72 24 valve engine cars. They have 3 stages of twin turbo kit that supposedly will work on our cars. I say supposedly because no one has stepped up and bought one yet that I know of, and it was designed on the Australian version of our car. The drawback? It's expensive. Keep in mind that the prices on their site are in Australian dollars, but it would still probably cost almost $6000 to get the stage 1 kit here in the US. But definitely feasible if you've got the $$$.
But for the real story on twin turboing a 3G GT, go here. If you're serious about the idea, check out the links on that thread as well to the original thread that he started on the .org site, and read, read, and READ. This guy knows his shit and did a DAMN good job with his car. He's at somewhere around 350 whp with the stock block (I believe running 15 psi, which would be the highest of anyone on a stock 6G72 block), but he's holding back on the tune to keep the block intact. No doubt that with a fully built block and a bit of a bump in the psi, as well as a little more aggressive tune, he'd push well over 400 whp and beyond (I think his setup could push around 450 whp at about 18 psi or so if he built the block and got a little more aggressive with the tune...not sure where his turbos would top out...). I'm considering sorta copying him myself honestly. The parts list I've come up with so far would run me around $2500...but you've got to know what to buy.
Above all, whether single or twin turbo, your main issue will be tuning. If you can fit the twin turbos in the engine bay and get everything else installed right, it should be no different than tuning a single turbo setup - which with our cars can be a cast-iron bitch. Only possible issue is boost coming on at lower RPM's and possibly creating a bit more of a traction issue.
Posted while I was typing my novel :lol:
Jbasol (the guy who has the setup I linked to) used the stock turbos off of his 1995 Dodge Stealth TT, they're 9b turbos. I believe if I remember reading right he had said they will start spooling at or even slightly below 2K RPM's. Tiny little suckers. :lol:
While building internals would be a good idea, he's shown it wasn't absolutely necessary. A cautious tune and a setup pushing 8-9 psi should be reasonably safe on the stock block, and I think it would produce close to 300 whp if not a bit more, as well as a metric fuckton of low end torque. Of course, go too lean and *boom*
With that small of turbos, no you wouldn't really need the internals, but going with a pair of 13Bs and wanting to push 15psi(talking 400-500hp), then you definately need internals, and probably should look into cryo strengthening.
I also definately recomend a manual boost controller, it's cheap, you can route it to the cabin, and better in the end than electronic(expensive) one. You also HAVE, and I mean HAVE to have a turbo timer, that will save a lot of money from blowing turbos by accidentally just pulling the key out after a medium to hard drive.
I ran two 20Gs on my GN usually around 15-20psi, I pushed 27psi a few times but I had trouble keeping traction.
Kampfbereit
The engine internals have to be upgraded if your approaching 300hp, the pistons just don't hold up.
Regardless, RPW does indeed have a twin turbo kit that will fit our engines, but I'm just concerned about the routing of the intercooler piping. I will be speaking to them this evening about pricing on just the manifolds so that most of the difficult work is out of the way.
Resident Asshole
Uhhh... yeah... That's why 3SI guys upgrade to FMIC's and ditch their stock SMIC's? That's why I have a nice huge FMIC to go on my VR4?
2 is not always better than 1.
0
Guest
this is true with breats and testicles but not turbo's jus get one nice sized and you shall be set
Kampfbereit
Just because people do it does not always mean that it's the right thing to do. Having the two side mounts I would imagine is more efficient than a big front mount, of course that's pending on horsepower requirements.
Resident Asshole
Going to a FMIC actually can simplify the piping as instead of needing 2 distinct pipes running to the throttlebody you only need dual piping to the FMIC and then a single larger pipe running to the TB.
That would be the shit if they would sell just the manifolds...although from a cost standpoint it might still be cheaper to modify stock manifolds. I dunno.
Pretty much what it boils down to is that if you want to, twin turbo is definitely possible, but it's either a) going to cost a pretty penny (RPW kit), or b) be a custom kit. But it can work, and work well.
Kampfbereit
That might be true, but like I said before running two side mounts could very well be a much more efficient setup, and efficiency is good.
Resident Asshole
Experience tells me if it was more efficient the high hp 3si guys would be running twin smic's... They run FMIC's... Logic tells me then that a FMIC is more efficient.
Not trying to bust your balls Russ, and I agree that whatever is more efficient is better... But the 3si guys have been there done that and they run FMIC's when they want more power.
I guess if you were shooting for 320hp like a stock 3si... Well then twin intercoolers might be just fine. :p
Kampfbereit
Not trying to bust your balls Russ, and I agree that whatever is more efficient is better... But the 3si guys have been there done that and they run FMIC's when they want higher efficiencies.
Higher efficiencies when they go up in boost you mean like when the turbos they upgrade to require more intercooling, then yes. Do you have any dyno comparisions with stock turbos to see which is best, side mounts or one front mount?
An outsider could go around and say "Those guys over at Club3G are all running superchargers, that must be the best way to go from my experience"
Resident Asshole
:lol:
Point taken.
Turbo Buick > you
:fawk2:
1 - 20 of 26 Posts
