1 - 11 of 11 Posts
hi everyone, I had a quick question there鈥檚 a fuse,ground, or relay at the the bottom of the upper intake manifold. Is that a OEM part or just a bolt on fuse and if so what would the amp number be? 2000 eclipse v6 auto any input would be appreciated thanks 馃檹
Automotive tire Automotive lighting Automotive exhaust Gas Font
Super Moderator
I took a look at mine and there is nothing attached in that area. In fact I do not see that black box anywhere on my engine . It could be something someone added ( aftermarket ) or it was deleted after the 2000 model ?
I was doing the valve covers and I remember disconnecting the plug from the box but I quess I lost it in the process of doing the other work but crazy enough I found that black box/fuse/relay on a 2003 gs at a junkyard it was underneath the other ground wires on the valve cover. So ima plug and play because they fit hopefully nothing burns or shorts I鈥檒l let you know what happens
1 - 11 of 11 Posts
