Has anyone ever run or is currently running this system? Im only looking for a mild nitrous system and I found this kit. Can anyone give any feedback on the kit?
The R500 Recluse is Venom's entry level nitrous system. The system is built using Venom's Patented closed loop fuel control system which ensures the proper air/fuel ratio under all operating conditions. The system features an advanced microprocessor based control module that will automatically terminate the flow of nitrous if the air/fuel mixture becomes to lean. You control the flow of nitrous to your engine using various sized nozzles (each kit contains 3 nozzles(50, 75, 100); the module will automatically control the fuel flow to your engine using the existing injectors. No modifications to fuel pressure required and best of all it works on all new fuel systems that do not include a fuel return line.
Kit comes complete with: Computer control module, nitrous nozzles, wiring harness, 10 oz. bottle, bottle brackets, hoses, fittings and installation Manual. The R500 Recluse fits all Electronically Fuel Injected Vehicles
