First off welcome. What model do you have? Usually it takes longer than 30 miles to readjust, usually around 100 miles from what I read but that is usually for the idle.
First off welcome. What model do you have? Usually it takes longer than 30 miles to readjust, usually around 100 miles from what I read but that is usually for the idle.I had a recent battery problem(the negative terminal end was very corrored probably because of water getting on it and wasnt getting any conduction with the battery). I replaced the negative terminal end with a new one and after getting this replaced ive been noticing a large reduction in my fuel economy. I dont know exact numbers, but on a 10 mile trip the fuel guage dropped about 1/10, which is horrible compared with how it used to be. Anybody have any ideas why or how to resolve his? My guess is that disconnecting the battery caused all the sendors to reset and now they have to readjust, but its been driven for about 30 miles already and i dont think it should take this long for them to adjust.
Honestly the best way to judge the fuel economy is to drive it down to say exactly half a tank while recording the mileage using one of the trip settings. Then when you refill your gas, look at how much you've filled it by. Then calculate the mpg, then repeat a couple times to get the avg. If it's below say 17city you might have a problem like it running to rich. If I remember, the RS/GS's gets like 22city.Thanks! Its a 2000 gs, everything is stock. Im hoping the problem is that they just are still adjusting and its nothing serious and wont require replacing anything. Ill try giving it a while longer and i guess time will tell.
