And how she sits now:
BC Coilover suspension
8Kg/mm front spring rate
12Kg/mm rear spring rate (dampeners revalved to match!)
Front control arm bushings replaced with solid black poly
Rear upper control arm bushings replaced with solid black poly
Rear lower control arm bushings replaced with solid black poly
Steering rack bushings replaced with solid red poly
Stock brakes with
Centric Cryo Rotors front
Centric Plain rotors rear
Stoptech Street Performance front pads
Stoptech Street Performance rear pads
Dunlop Direzza ZIII
TRD 3 point rear strut tower brace
Rod Millen Motorsports front strut tower brace
Magnaflow 14210 muffler
Ported stock exhaust manifold
K&N Typhoon CAI (with stock MAF housing installed)
Infinity BassLink securely mounted in trunk
PIE TOY2 auxiliary input box for the factory radio
Front doors and rear trunk floor sound dampened
Antigravity AG-1601 16 cell LiFePo4 starting battery (4lbs, 480CA, 16AH)
Lexus chrome door strikers
Stainless steel door striker covers
Auxiliary trunk light
LED dome light, 5000K OEM Lexus color
OEM HID housings with Osram Nightbreaker Unlimited D2S
9011 high beam bulbs
Di-Chroic yellow fog light bulbs
JDM Astar 3014 T10 amber LED for front side marker
200lm T10 LED's in front parking lights with special modded bulb holders to turn them 90 degrees so they shine into the high beam bowls
Diode Dynamics tail as turn module as front turn signal repeater for side markers
15" electric air horn with custom mounting brackets
16" flexible mast antenna
Stock brakes with
Dunlop Direzza ZIII
