Water pump w/o rear housing
998 views 0 replies 1 participant last post by  gtada
I'm about to replace the timing belt on my GT and figured I'd swap out the water pump while I'm at it. Mitsubishiparts.com has the OEM water pump for $150, but I found significantly cheaper water pumps "without rear housing".
If I go with one without the rear housing, will that totally complicate things? Or is it as simple as taking the rear housing from the old water pump and slapping it on the new one?
