This thread is long, so I've created an index (currently the page number don't match to the content because of the change of the forum format. I'll be working on that. I'll also be adding all the pictures that were removed by a certain bullshit photo cloud service. )
INDEX
Page/ Topic
1/ Getting started; First tune in closed loop.
2/ First ZT-2 /EvoScan datalog with lean condition;
Aeromotive 1:1 FPR and –6AN connectors installation.
3/ Deyeme motor mounts install; Walbro 190 install;
Tuning in Open Loop.
4/ Baroscope; 100% Load issue; First Dyno.
5/ Log from Dyno; Bent valves at track; Long block Rebuild.
6/ 440 cc injectors ordered, Long block build.
7/ Track time; Oil leaks at cams, installed Ingall's Stiffy, and VR-4 fuel rail.
8/ Vortech SFMU install; SDS removed/serviced.
9/ Long block rebuild #2; VR-4 head gaskets; Pulse Plugs install; Walbro 255 install.
10/ 10 psi; Wastegate as boost controller discussion; 2nd track time.
11/ Boost Cooler install; Photos of setup; Emissions preparation; Invidia N1 removal.
12/ Heat shield; Passing emissions; boost cooler test/first trials.
13/ SDS weld cracks, removal of butterflies, ignition wire discussion.
14/ SDS weld repaired, B-day Cake, 10.7 psi, Megan OE-RS install, misc. discussion
15/ Stage 2 with wastegate discussion, Draw-thru piping pic, Quaife and FX300 bought, Big Map.
16/ More Big Map discussion, LSD install, Brembos being prepped for install. New rims and tires.
17/ Brembos, Front Lip, Oil Catch Can, Stage 2 axles, and EVO TB seals installed. Datalogged 11.4 psi and finally hit high 13's in 1/4. Extra V-5 and V-2 SDSs. Center Section redone.
18/ BOV failed and replaced, new built block installation, new Damond venting oil catch can. Rebuilt Engine spun rod bearing. Rebuild the Rebuild. Heads with RPW valve springs.
I got my SDS in. It would have been nice if GCT sent me couplers so I could actually hook it up to the TB! Idiots.
The good thing is, even though the blower is just blowing into to engine bay freely (and loudly, I might add), it gives me a chance to be sure that all the belt tolerances, oil feed lines, and the blower, are working properly under a light load.
For example, I noticed, after a light 8-mile drive, a little bit of oil at the outlet of the blower. I wiped it clean, and if the oil reappears, guess who gets to go to Vortech's factory for new oil seals? :rant2: Better now than later...
So, anyhow hope to have a local shop finish the piping this week for me and be on with it. I plan on documenting the install in a separate thread when I was completely done, but I thought some of you would like to see how I altered my CAI. :twothumb: Enjoy!
My mods list that I will update from time to time is here: Repforenzo's 2003 GTS with SDS
INDEX
Page/ Topic
