hi all,
When i'm doing visual inspection on the car today, i've noticed that the axle connect to the knuckle ..
43070
Is that Knuckle supposed to be stationary or moving?
I turn the wheel and it's moving back and forth when the axle moves.
Do we know what it's called?
Thanks.
Is there a torque spec for it?
Thanks.
It's a half shaft bracket. I believe they're M8 bolts. Just tighten them around 35ft lbs and call it good. Throw some loctite on the threads if you're worried.
I will do that..
Thanks so much for the information.
