421 - 426 of 426 Posts
Some notes to help:
215 means 215mm width, and since 2.54cm = 1 inch this means it's about (rounding off) means an 8.5" wide tire. Still though it would work a little more is recommended.
The 50 in your #'s means the height of the sidewall is 50% of the width, so ~ 107.5mm height. You can vary the width and height as a %age if you match up the actual result and don't go too crazy. For example a 225 / 45 / 17 tire would be 101.25mm height. Shorter, but not drastic. 235 / 45 / 17 is even better at 105.75mm height.
I think you can do 235 / 45 / 17 at that offset but it's been a while so I'd read backwards and check for people who have run it or go re-read the first post in this thread to be sure.
Thanks for clearing this up. Must have mis-typed in the calculator when I was figuring out what width wheels a 215 would fit.
-Alex
Will 17x8 fit my 2004 Mitsubishi Eclipse Spyder GTS I have 17x7 factory rims on my car now. The rims I want are only one inch wider. I don't really want to do any mods to the car to get the rims to fit. I prefer just to put the rims on the car. Please let me know if these 17x8 will fit my Eclipse without mods, thanks
Is it bad that I've been running 225/45/18 on my eclipse (2003)for a year now? She seems to handle well. Should I drop her to 215/45/18? She had 225/40/18 when I bought her but they got fat knots and nobody had that size.
USN
Your speedometer will be a little slow compared to normal, but not a huge difference. Using the tire size comparison, 215/45-18 would be closer to stock. It's 0.6% difference compared to 2.0%.
