I recently bought an 02 eclipse gt and I am trying to install a sub and amp. Where do I need to drill a hole through the firewall to run a power wire? I have been told behind where the clutch pedal should be (manumatic) but I'm not sure exactly where. If you could provide pictures that would be ideal.
Willful Aspirer
No need to cause unnecessary damage to your firewall. There is a rubber gasket for your window wires in your door you can use, and there's another rubber gasket where wires runs through your fender. Use either one of those, just cut a hole in the rubber and feed the wire through and you're done.
It will come out in the engine bay.Run it through the door grommet to inside the fender, then the grommet inside the fender to the engine bay.
