Well i searched and searched, found similar problems , here is mine.
2001 stick, starter always was slow, then failed, replaced it. 2 weeks later it started most of the time, sometimes had to push start. pop starts easy.
then one day it wouldnt start even with a jump, turned over fine, no start, it pop started with a huge cloud of gas smelling smoke, then ran fine. threw engine code, crank position sensor.
then, my foot slipped off the clutch and i broke the cv axle, had it towed to mechanic.
now it will not start at all, except when push started. they thought maybe the ecu, but no way to test and too much $$ to throw that part at it.
today i told them to check the clutch switch w green and black wires, does that feed the ecu?
PLEASE HELP ME car has been in shop since november, my back up astro van just died and if it can not be started with starter i cant get inspection in pa and the car will be done, i love my car, planned the turbo.....so bummed.
near west chester / philly pa, if there is a 3g specialist i will have it towed to you.
