1 - 7 of 7 Posts
So I recently decided to put dynamat under the doors trunk ect. Anyway, i was in the process of removing the door panel and i took off the lock/window control piece. I removed it from the cord below. However, when it popped apart, two small metal pieces that are bent, came out as well.:uh: Now my locking still works but the power window button is loose, and doesn't control the window. Im not sure how the two metal pieces go back or if its something else i did that caused the window to no longer function. I would appreciate the help!:D
Damn, a third post on the problem, and still in the wrong section...
1 - 7 of 7 Posts
