So I recently decided to put dynamat under the doors trunk ect. Anyway, i was in the process of removing the door panel and i took off the lock/window control piece. I removed it from the cord below. However, when it popped apart, two small metal pieces that are bent, came out as well.:uh: Now my locking still works but the power window button is loose, and doesn't control the window. Im not sure how the two metal pieces go back or if its something else i did that caused the window to no longer function. I would appreciate the help!:D
haha na i tried it both ways i think it has something to do with the two metal clips that came off but im not sure where they came from or how they go back on.
Damn...I didn't know which of your two posts would be best to reply to...:lol: A picture would help a lot so we could see exactly what two metal clips you are talking about...:bigthumb:
ok the metal clips came from the top of the wires plastic top the two metal pieces that are bent that go back and forth i figured thats where they came from after looking at them for a whil, i hope i can get em back in there and for them to work :)
yes it worked, they were the two metal pieces that flip back and forth underneath the window button that touch the two prongs from the button itself
