They are low impedance so you will need either a resistor box out of an EVO or you will need your own resistors. I can get you a resistor box from an EVO for another $40.
All DSM and EVO injectors use the square plug. You will need to solder on new clips to use either DSM or EVO injectors. The only drop in injectors would be WRX style injectors which share the same clip. You just have to find top feed injectors instead of the side feed injectors found on the STi.
Since it seems that there is a price war here, I'll step out and let you deal w/ chino. I'm not that desperate for money.
Related Threads
Mitsubishi Eclipse 3G Club
2.8M posts
48.7K members
Since 2004
