Ive been making a list of dsm parts that are compatable and interchangable. I seperated them by the way these would be wanted
1=Cars with Dual Piston front brakes
-2000 Eclipse GT
-1992-1996 Diamante Wagan and sedan
-1997-2004 Duamante
-1992-1999 Eclipse 4wrd with solid rear disc
-Feb 1998-2000 Galant v6
-1990-1995 3000GT SL model
2=Cars with same calipers as a 2000-2001 Eclipse 4cyl
-Febuary 1998-2001 Galant 4cyl
3=cars with same calipers as a 1995-1995 eclipse Non Turbo
-1995-1999 2wd turbo Eclipse
-1995-2000 Dodge Avendger
-2001-2004 Strarus 4cyl coupe
-1995-2004 sebring 4cyl coupe
4=cars with same calipers as a 2002-2004 eclipse 4cyl or 6cyl
- June 2000-2001 Galant v6
-2002-2004 Galant's
-2001-2004 Stratus v6 coupe
-2001-2004 Sebring v6
rear calipers are all compatable from above vehicles except sebrings(they have a smaller brake not worth swapping)
Brake lines are also compatible from all vehicles, if you are going for a stainless kit, id use a 95-99 eclipse turbo 2wd set.
I made this because I think we should start to check junkyards for cheap upgrade options for brakes. I will be checking my local junkyards for any upgrades and posting my findings, maybe some will be for sale so keep checking and good luck with these brakes!
-2000 Eclipse GT
-1997-2004 Duamante
-2002-2004 Galant's
