21 - 40 of 115 Posts
Discussion starter · #21 ·
Not sure if you were asking for that or these
Viair 380C Air Compressor
Part Number:38033
Voltage: 12 Volt
Max Amperage: 17 Amps
Max Pressure: 200PSI
Max Duty Cycle(@72%F & 100PSI): 100%
Flow Rate @ 0 PSI (13.8 Volts): 1:48 CFM
i have the same setup and its very reliable....only bad thing is if you like showing off like me get a bigger compressor or get 2 big compressors like i did. oh, and the price is very good and if you decide you would part the kit out i need the rear strut bags
just wanted to chime in on owning this kit. I bought one for dirt cheap on ebay a few months ago. I bought a full built avs switchbox and it made it alot easier to install. Also i bought a dc5000 compressor off of ebay, and for hijacker, its small, compact and with leave you with enough air to show off. I love this kit.
also i forgot to say, i bought a 3 gauge bezel that goes in a din. Well i have to dual needles for the bags and a gauge, all easy street btw, to rear the tank. If your going for a good look, i would put them under/over your radio depending on how you radio is set up.
If anyone is interested about that i will post some pics up.
Also the gauges are right there in your line of sight to read.
