So I took my car down to the local shop and got a few minor things fixed, in the meanwhile I asked them to look into why my car rattled so much at stoplights while idle. When I shift into Neutral all the rattling goes away. They said the transmision mount was cracked, and that the other mounts were old and soft. They wanted 600 for parts and labor to replace them.
Anyway I am looking into a more DIY option, and have come across the Prothane motor mount option. However I want to ensure that I am doing the right thing. I read on the forum here that you should not "cut out the rear mount because the prothane installs over the stock rubber." Now if my transmission mount is cracked, I assume that is the rear? If so I assume I cant use the Prothane option? If that is the case what other options do I have?
This is a daily driver and all I want to do is get rid of these annoying vibrations and rattling at idle.
Thanks!
Thanks!
