FS: New Walbro 255LPH Fuel Pump
834 views 14 replies 10 participants last post by  MitsuBoy38
EDIT: I sold the new one. I have a used one I just pulled out of my car literally last night so I know it for sure works. It also comes with a filter to. I'll let that one go for $50
PayPal is damon_g@rocketmail.com if you decide you want it. Thanks. ***
I have for sale a brand new Genuine Walbro 255LPH fuel pump with filter. I was gonna put this in my Evo but decided to go with the DW300. Asking $75 shipped.
#8 · (Edited)
Pretty easy.
Heres the video I used. Same thing though. I've done it on a 3G before. The hardest part is getting the damn clips off. Then getting the assembly and ring out was a bitch to, and getting it back in. Just use common sense though and maneuver it around and it'll work itself.
Direct replacement. There is thread here some where.
I'm not sure if its direct. If i remember i had to shave the housing a little bit with a dremel cause the walbro is a touch longer. Pretty easy to do though.
http://www.youtube.com/watch?v=BK73u1TK0VE
#10 ·
It fits with minor modification. It's not as easy as some people make it out to be. I just installed one a week ago. Make sure you follow the direction Drilling out your return line is of the utmost importance. If you do not drill it out it will raise the pressure by a good bit. You don't want to run around at 50psi when you're supposed to be 38psi. Good luck to who ever buys it. Good luck with sale OP.
