Okay on the 2003 Eclipse GT.. I'm GOING TO change my oil by myself for the first time. I have a few questions. Since the Oil Filter and Drain plug are reachable from ground level, is there a need to actually jack the car up?
I was thinking of running up and getting from AutoZone a drain pan oil filter and some oil, but I want to make sure I don't need to jack the car up first. Because don't you need to the oil to run ALL the way out, with the car flat I don't think it would do it, unless I park on the driveway at an incline, even then I'm scared of dripping oil onto the Driveway
Second question, when you take the OLD filter off and go to put the new one on, do you coat the ring with old oil or new oil?
Any help as always is appreciated.
