Passenger Door Electonics Issue
1.1K views 2 replies 3 participants last post by  Ken
So a while back the electronics in my passenger door quit working, door locks, power windows and the mirror intermittently lets me move it left to right. Yes the window lock is unlocked. I looked through my manual and looked at all the fuses, fuses look like they are in tact. I'm at a loss for what it is, thought i would check here before i decide to take it to an Auto Electrician! Thanks
it's a 2003 Mitsubishi Eclipse Spyder GS, the problem presented it's self as intermittent until about 4 months ago and then went completely dead! Any Suggestions?
I would remove the switch panel from the door and try directly jumping the wires to see if they will activate the window motor & door lock.
If they will, then the problem is in the switch. If not, the problem is in the wiring.
Start there and report your findings and I will try to help you the best I can.
