Snow alcohol/water injection
3.9K views 109 replies 7 participants last post by  Ev0cl!pse05
well guys i just ordered a snow performance boost cooler kit,im goin to start running a 50/50 mix.....i been running 15psi.
With the kit im debating on increasing the boost to 18 pounds or just keep it at 15 psi and just increased timing and run alittle leaner,i need opinions guys,what you all think???...to anyone who dont remember my setup is here
http://www.club3g.com/forum/rs-gs/115901-my-eclipse-turbo.html
#2 ·
since it looks like you are on the stock head and it doesnt flow too well at higher boost levels, i would say re-tune the fuel/ignition for the meth and stay at 15 psi. i'm sure there will be input from people who are smarter than me.
:agreed: Id focus on gettin it dialed in at the 15 lbs 1st. You prolly wont get much more flow past 17. Although thats been the estimated choke point number. Not necessarily proven but very likely. Id even guess youd lose power at that point as well too since the turbos out runnin the heads capacity. :dunno: Youd prolly just confirm what we alreadyve heard, turnin it up to 18lbs.
thanks alot!!!,thats what im goin to do,with alittle higher timing and leaner mixture i can squeeze out some more horses! and still be safe,i heard that the head will be maxed out at that psi,but some people still run it lol,i just wanted to get more opinions..thanks
im goin to upload pictures of the install when i get the kit this coming tuesday!!!
its goin to be a great christmas eve!! lol
#5 ·
quick question,as you may see on my engine bay picture,im using the stock evo intercooler pipping,the nozzle have to go as close as possible to the throttle body,but since theres is the long rubber elbow,could it be safe to mounted it on the alumminun pipping since its like 6 inches away from the throttle body??,hope you guys get what im trying to say!
#10 ·
well look what i got today!!! :ndance:
[/IMG]
[/IMG]
[/IMG]
im goin to install it tomorrow morning,any advices are welcome,i dont have much space on the engine bay,im figuring out were im goin to install the reservoir
#13 ·
Negative!:nono: youll want that pump gravity fed so that means the "in" port of the pump will have to sit lower than the reservior. This is the location of the bottom of the washer fluid reservoir.
If the cops werent super gay out here id have chosen a different location for the res. and pump. Check my thread to see what ive put together so far. Trust me, hop under there and theres no logical low point to mount for a proper gravity feed. I asked about that to wondering if the pump had a sufficient suction but its just adding a risk once the demand you set on the controller begins.
thanks men!,i was thinking of putting everything on the truck just like steady did,but on snow intructions it says its recommended to get the solenoid if you goin to mounted on the truck,im undecided yet(theres no space on the engine bay!!) =(,and yea definetly the pump have to sit lower than the reservoid
I saw this thread late so forgive me if I take the pump placement out of context. Just want to show you what I did.
There is a great spot right next to the wiper reservoir I found. I had to make two brackets that bolt up to the chassis.
And then from underneath you can set where I tapped the reservoir. The tank is above the pump and even with the slight bow in the hose, gravity can still do its job. Plus I never plan on letting the reservoir get to low.
Reactions: AzN-SoLjA
#17 ·
no it looks like he tapped the bottom of the wiper tank. Never thought of fabin brackets. Couldnt visualize it.... I knew under the headlights was a prime spot to mount in the engine bay though. Clean, logical, install repforenzo!:yesway:
#18 ·
yea you right,tomorrow im goin to check to see if there is space for the reseroir,if not then i will tappe the washer tank,i dont want to wait a week for the solenoid to come in,it will be nice to mounted it in the truck though:lol:
#19 · (Edited)
Thanks for the kudos guys. There isn't enough room for the standalone boost cooler reservoir, but you won't need it. The wiper reservoir is nearly a gallon and you can still use it to clean your windshield when you need it.:)
The brackets were easy to make. I went to Home Depot and bought two large heavy duty 90 degree wood brackets. I cut them just after the angle to make them look like two little skis. It wasn't hard at all. Mount the pump to the brackets and then put the whole assembly on the chassis ledge and measure for your drill holes. It worked great and it is solid.
Unfortunately, the first time I tried to mount the pump it sliped out of my hands, hit the floor, and damaged one of the inlet/outlet connectors. :eek: I had to order a new one.
#22 ·
well i tapped the washer tank alreday,put it back in,wire all the electrical connections and tomorrow i just hae to put the pump,thanks repforenzo!,im doin the exact thing as you,did you drill exatly on the edge? you use bolts with nuts then right???
Yup, I only took the two photos and I have the same ones on my thread. To be honest, once you pull out the headlight it pretty easy to see how it will fit.
I just did some visual measurements on making sure the pump was low enough in relation with the reservoir and so it wouldn't hit my fog light.
So in order: 1) Modifying the brackets: I cut the brackets so they 'hang' on that chassis ridge and then drilled the chassis holes in them 2) Taking one of the cut brackets, I slid under the car with the pump to visually check where on the brackets the pump needs to be mounted. 4) With that info, I drilled two holes on each bracket symmetrically and attached the pump. 5) Now that the pump was on the brackets, I placed the whole assembly on the chassis ridge to see where it would fit without hitting anything. Once I found the sweet spot, I held onto the assembly while I took a sharpie to mark the drill points through the pre-drilled bracket holes. This way everything lines up. 6) Finally, drill the two holes on the chassis and with nuts and bolts, attach the pump assembly.
That was the way I did it and it was a snap.
