I think not. The Genesis 1.1.
The Genesis 1.1 consists of four major modules: two midrange tweeter screens and two bass towers. Each module is 7.5 feet (228.6 cm), and is covered in the most beautiful plantation grown South American rosewood that money can buy and is hand finished to the most exacting furniture grade standards possible.
Each of the midrange/tweeter panels is 42 inches (106.4 cm) wide and houses a 75" tall ribbon midrange and twenty ribbon tweeters on the front and six in the rear to form A near perfect dipolar line source array. Each baffle is machined out of a solid piece of one inch thick black Corian.
Eachtweeter is our own proprietary 1 " ribbon built from an incredibly thin membrane of Kapton and aluminum (.0005" thick). Behind the flat diaphragm of the tweeter is the motor, a precision machined and focused magnetic structure.
The midrange module is A newsingle 75" dipolar ribbon driver. A push pull dipole configuration was chosen to eliminate the distortioninherent in many single ended ribbon designs. The diaphragm of thisdriver is made of a very thin 0.001" thick Kapton film laminated with a thin aluminum strip which acts as the voice coil of the driver. The entire device is suspended in a powerful magnetic field created by over 30 feet of barium ferrite magnets.
The two bass towers stand seven and a half feet tall, 18 inches (45.6 cm) wide and house twelve servo controlled twelve inch metal cone woofers individually driven by a massive 12 channel 4000 watt servo amplifier, housed in two Tower chassis and connected to the woofers via a custom 30 foot cable hand-crafted by AudioQuest. The fully discrete servo amplifier is remote controlled and functions include volume, low pass, high pass, phase and power. Inside there are 3 toroidal transformers that deliver the power, which is adjustable to any line voltage a customer might desire.
The crossover module for each of the midrange/tweeter panels is housed in a separate Corian enclosure with a tuned suspension system to isolate it acoustically. Inside the crossover, Genesis has incorporated the world's first multiple tap copper foil inductor for the midrange and our own proprietary polypropylene film and foil capacitors for the tweeter array.
The complete Genesis 1.1 system consisting of themfive separate elements weighs over 1 l/4 tons and is shipped in 6 wooden crates.
