TizaL's 03 GTS 6G72
36K views 107 replies 65 participants last post by  tizal
TizaL's 03 Silver GTS w/youtube videos! {last updated@5/8/2014}
Welcome to my parking space online. I’ve had it since april 2004 and this is what I have representing it out there.
Stock exterior
2003 Eclipse GTS v6 3.0L 6G72 {current}
Stock Engine
Engine Middle View currently.
Stock Radio Console
Current Radio Console
Stock Trunk
Current Trunk Setup
My awards so far…
http://i60.tinypic.com/8y85xv.jpg[img]
Unique angle
[img]http://img205.imageshack.us/img205/6169/gotdubsyn3.jpg
The Tour
Headlight pictures and different setups at night;
Got rid of the cancer.
Injected Pure Goodness.
Engine Left Side currently.
Engine Right Side currently.
Optima Battery with VoltMeter on Terminals
Nighttime battery view
The Greddy Exhaust.
Stainless Steel Brake Lines
LED Bulbs which look way cooler than standard.
Upgraded Fuse System to GLO-BLO fuses. They light up if it blows!
Glo-Blo Fuse System continued.
Wolo Bad Boy Horn w/Air Compressor. 2x louder than stock!
Interior Console day time
Interior Currently night time
SAFC mounted in my clock panel
Kenwoood DNX7140 Double Din GPS/MP3/DVD/CD Player w/USB
Lower Console Switch Panel, Wireless TPMS and Custom Switch Panel
Escort 8500 X50 Blue LED Radar Detector Hard Wired in on custom bracket.
The rear cargo area. Nothing much.
I made a new trunk lid with plexiglass and some plywood+speaker carpet.
Rear view without trunk lid. Amp and Power Cap
Blue illumination when turned on.
Left Side view of stereo system.
Middle view of stereo system.
Right Side view of stereo system.
Rear View Camera
YeaH BoyEE!
Before/After Eibach ProKit springs 1.25" drop
Anti-Flash Protection from photo radar.
You can get it here at Photo Stopper Camera Radar Anti Flash Permanent Spray
When the car alarm goes off, thats the camera that takes your pic and sends to my remote.
Transmitter for alarm to remote.
And that is what I see on the LCD remote from the camera. See who is actin a foo.
Scytek VisionGuard 8000 features;
Full Color Camera with Night Vision
Remote start for this manual transmission!
Automatic picture capture upon security violation
Selective picture capture through the remote
Store and recall up to ten discrete images on the LCD remote.
One Carbon Fiber 2-Way True Color Picture remote control.
One Carbon Fiber Slick 5-Button Remote With Super Bright Blue LED
Built-In Parking-Light Relay Programmable (+/-)
One 5 button code hopping remote control Sleek Carbon Fiber w/Super Bright Blue LED
Plug In LED and Override Switch
Remote Start Tach Monitor
Starter Interrupt Output
Dual stage Electronic Impact sensor
Power door lock control
Trunk Release
Parking Light Flasher programmable polarity
Courtesy Light Control
Anti-grind Option
Gas or Diesel compatibility
Cold Start timer
Selectable Engine Run Time
Turbo Timer (adjustable) not used in this car though 
Smart Network Port to interface with scytek software on my laptop for alarm programming and diagnostics
Securetire Wireless Tire pressure monitoring system
Product Description :
SecuTire is the most competitive Tire Pressure Monitoring System (TPMS) product in the market. It monitors the pressure of each tire independently in a real time fashion. When low pressure is detected, SecuTire will send the driver a warning signal. In addition to improved driving safety, other benefits include longer tire life and enhanced fuel economy.
SecuTire system consists of sensors, signal transmitters and receiver. The sensor and transmitter are integrated in one unit conveniently. Pressure sensors installed in tire valve stem will detect tire pressure and send the information via RF technology to the receiver inside the vehicle. Visual and audio alarm signal will function once preset pressure threshold is met. Through SecuTire system, drivers can have a real-time and direct visibility of tire pressure, with peace of mind and enhanced safety. -????????????????
All the Bullshit;
EXTERIOR
West Wings Body Kit Color Matched Sterling Silver
18x8.5 Akuza Road Concepts Sublime Chrome Rims
Wanli S-1088 Performance StreetTires {Siped} @235/40/ZR18
Eibach Pro-kit Springs 1.5" drop from stock. Eibach Rear Camber kit, Rear-view Backup Camera
KYB AGX Nitrous Gas Red Shocks, Cross Drilled/Slotted Rotors w/ Duralast Ceramic Pads, Stainless Steel Brake Lines, duplicolor paint yellow calipers
StreetGlow White Neon Lights Gold Series, Aluminum Grill / Locking Gas Cap, Tinted Windows @20% Visible light, Spyder LED Smoke Taillights, Clear Smoke w/31 LED,
Smoke Projector Headlights w/HID 6000k Lights/White Halo/8500k H1 Purple Brights
Smoked lenses front bumper w/24-LED amber bulbs, Smoked 8-LED running lights,
Smoke Foglights, LED White Reverse-Lights, License-plate/Dome/Pkg.
Smoke Rear View Camera
6G74 ENGINE POWER==192hp/191tq EMISSIONS LEGAL
Apexi S-AFCii installed+tuned by MAC AutoSport {display mounted in-dash}
Optima Yellow Top Deep Cycle Battery 750cca MF=09/11 pt#34/78 mdl#9151189
AEM Cold Air Intake w/AEM DryFlow Air Filter 2.75"X5" part#21-202DK
Yellow/Grey/Red/Thermal-Chrome Wire loom scheme
Two Rapter Platinum Battery Terminals w/ Stinger 0ga Red, 0ga Stinger HPM SilverGnd
Audiopipe Inline ANL Fuse Holder w/120amp fuse for alternator w/Blue LED status
OBX Racing Yellow Radiator Hoses and 3A Racing Yellow Vacuum Hoses
Magnecore Spark Plug Wires with NGK Iridium Spark Plugs
Custom Motor Fabrications {CMF} Header/Down-pipe 2.5” {1st Generation}
Magnaflow High Flow Catalytic Converter 2.5”, Greddy Evolution II Rear Exhaust 2.5”
Baker Electronix o2 simulator on 1st bank 2nd oxygen sensor.
Redline Water Wetter Coolant Additive with Prestone 50/50 antifreeze
Royal Purple Synthetic Oil 5w-30 w/Royal Purple Oil Filter. BG Syncro Shift Transmission Oil, GLO-BLO Fuse system. Lights-up when a fuse is blown!
Wolo BadBoy Electric Horn w/Air Compressor
INTERIOR
Carpeted Trunk w/Black, Custom Trunk Lid Cut-out w/ PlexiGlass JL, Blue Neon Light
Two FiberGlass custom 10” Subwoofer Boxes {.9 cubic ft internal}
Two JL Audio w3v2-d4 10" Subwoofers @2 ohms {MAX_2_DATE=138.1DB}
Pioneer 6.75” TS-A1782R FRONT 4-way Pioneer TS-G971M 6”x9” REAR
Audiobahn A1502DP Chrome Amplifier 300rms x 2ohms w/ADM100T Voltmeter
Power Acoustik PCX-5F 5 Farad Digital Capacitor
Kenwood DNX7140 w/Garmin Navigation+USB, Power Acoustik PCX-5F
B-Quiet Sound dampening material on doors/trunk/under seat, Dash Mat
4ga Blue Power cables, 4ga Ground Silver Ground Cables, 12ga Neon green speaker wire
Dragon Leather Steering wheel cover, Escort 8500 X50 Radar Detector Hard-Wired in.
ScyTek VisionGuard Car Alarm w/ Camera&LCD remote
SecuTire Wireless Tire Pressure Monitoring System, RRE Rear Strut Tower Bar, B+M Short Shifter , Switch panel with amber to halo/running lights, green to neons, others light up but not active currently. GoPro mounted in front windshield.
Video Section
Here is my sound clip of the eclipse with all the mods. The fans cover up a little bit of the sound but you can hear the tones once the rpm goes up. More video in the works!
Tuning session beginning
Online Stereo Competition Code
<A href="http://www.carstereo.com/installs/photo_gallery_album.cfm?galleryid=3987"><img src="http://www.carstereo.com/images/car_stereo_vote_banner_4.gif" width=246 height=105 alt="Online Car Audio Competition Competitor" border="0"></A>
More Video in the works! check back often!
I'm not a huge fan of the wheels, but the rest looks pretty good to me. What you did with your subwoofers is similar to what I want to do with my audio project. How did you go about doing that?
** If you do not feel like cluttering up this thread, I just sent you a PM. **
#11 ·
Where did you get the upper radiator hose from??? I have been looking for a new silicon one, but have been unable to come up with anything.
What mde you choose yellow under the hood?
The standard chrome loom is very common and should be available locally for you. The hard stuff to find is the chrome red and chrome blue. ;) (Which I have access to and sell.. hehe
#21 ·
thanks for the feedback. i updated the post to contain links to the products in question. As for the radiator hoses and various knick-knacks you can find them all on ebay for reasonble prices. The sub boxes were made by a fellow in another forum and i don't think he makes them anymore but if you want an idea for a molded stereo box, just use a basic subwoofer single box and carpet it over with a big square of that speaker carpet and it might work. :hspin:
#27 ·
probably. I work south of denver in lone tree, live in the middle {6th and federal} and travel north every weekend to lafayette for family. Plus i tend to take canyon runs behind boulder but not unless its a really nice day. Occasionally I go to some shows and DB drags if they involve free prizes in any way so you might have seen it here too. If you see me around, feel free to say hello.
#29 ·
it was expensive. The alarm i got off ebay for about 300 shipped, and i spent about 1000 getting it installed. Every year I get tax returns from my hard work and that bill pretty much took it all, but its worth it to protect your investment IMO. Normal car alarms like viper/beltronics/clifford were nice however they didn't give me the information i needed if the car were violated. The alarm would simply make noise and cry essentially until someone who cared enough came along to turn it off. If you look at peoples' reactions to a car alarm you find that it is one of the most often ignored sounds out there, which is why i wanted to get something that had more of a response to it. Overall, it is really cool and even has remote start for the manual. Finally it has a network interface port so you can hook a laptop to it via special cable and run the software from the website to program and run diagnostics if you wanted. If you want to know any more, just ask! :metal:
