I need a good engine from an 03 eclipese gts, whatever other years work im not sure on. Car got hydrolocked after 9 inches of rain, if you have on or know of one let me know. It is a manual with v6 with mivec. :idea:
umm, 03 gts w/ mivec :lolspit: sorry the 3g doesn't come with mivec...you just need a gts engine 03-05 will workRaced Guy said:I need a good engine from an 03 eclipese gts, whatever other years work im not sure on. Car got hydrolocked after 9 inches of rain, if you have on or know of one let me know. It is a manual with v6 with mivec. :idea:
yepNabeel said:isn't mivec the new 4g engines? good luck
its not mivec, it has short and long runners in the intake plenum that open up at different points in the rpm range.Raced Guy said:Yes it does have mivec, or a form of variable valve timing, hence the power difference from the gt and gts.
The 3G did not come with Mivec that's only the 4G and new EVO 9.Raced Guy said:Yes it does have mivec, or a form of variable valve timing, hence the power difference from the gt and gts.
You need to do some research on your own car. As these guys stated, the 3G does not have variable valve timing, period. You're getting confused with the special manifold that are on GTS trims (And the 03+ GT Spyder), which is a simple set of butterfly valves that are actuated according to RPM flunctuation. Old tech that's been used by Toyota since the 4A-GE engines been out during the mid-80's.Raced Guy said:Yes it does have mivec, or a form of variable valve timing, hence the power difference from the gt and gts.
