EPAS in the ol Blue Bomber
3.4K views 15 replies 7 participants last post by  grfft3r
As I'm sure everyone knows I can never leave good enough alone, so I have yet again done another first on the 3g.
I have installed electric power assisted steering on the Blue Bomber. I have to say very happy with the result.
Made the steering much more responsive and I think more fun to drive.
I will admit I also had a problem with my rack leaking after the conversion,
tried fixing it but no luck so I came up with this. Also I can control the amount of assist which is cool.
Got this unit from a Saturn Vue my shop was parting out, so it was free and worth giving it a shot. Here are some pics of the two columns becoming one.
This was a fairly easy conversion to do.
Also using my car as a guinea pig it is just another thing my shop can offer my hot rod customers, hidden away power steering conversions.
As usual I'm sure there will be some haters.
I have those same pedals! (i think)
That is pretty badass though..must be really smooth
very nice!! So what did you do with the rack and pinion leaking? Since you still need a rack and pinion what did you end up doing? new and route the outlet into the inlet?
curious on prices for these so i typed in "electronic power steering" on ebay and the first like 10 items were all saturn vues LOL
#10 ·
Except those GM units are very failure prone, usually they just stop assisting or overheat during parking lot driving and loose assist till they cool down. I'm not so sure I'd trust it on the autocross track. There are other makes with more reliable units like Nissan, Toyota, Mitsu, etc. GM as an early adopter had issues, especially in the Cobalts. Even Ford's units were problem plagued and some new models still have weird issues. Of them all though, I think Nissan has the best road feel.
You could have done a setup like Toyota (did) or Mazda does and used an electric pump to push fluid as needed. My moms 2010 3 has that and Toyota did for the MK2 MR2.
#11 ·
Fluids were my problem, so not a solution for me, also most all of these units are made by koyo, and damn near make racks for everyone even the stock one in the 3g. I did test mine pretty intensively with no issues. But the true test will be when I get down to High Prairie Raceway, we will see if it holds up. The fact it was made for an suv and is now in a car it may not work as hard as it normally would.
#13 ·
Good point. It'll be interesting to see the results, you can always hack it up to add extra cooling to it as well. If I remember correctly the motor itself has a thermal diode, simply adding an 80mm fan to blow into the motor windings or at the power controller may help a lot. There's literally NO airflow under the dash to cool those things down.
