21 - 40 of 142 Posts
Discussion starter · #24 ·
Recently i threw a p0705 code. I replaced the sensor and everything is cool. I'm no longer doing the 3.8 manifold swap(ill just wait till i do the whole engine swap) instead I'm getting the the 74 flange so i can run the 74 Tb on my GTS manny. After thats done, I'm going to finally get my tune. I'm hopping for 230 hp 215 tq at the crank.
Game plan.
+Monday-Purchase 74 flange, Aem Wideband, transcooler, 1.3 cable
$40+$160+30+$150
+Friday install transcooler & AEM
+Following Friday 74 tb installed & tune
hopefully everything goes according to plan.
Discussion starter · #25 ·
Fixed the p0705 code.
Game plan changed again.
I order the 6g75 manny and 6g74 flange today from silvertune, so obviously I'm back to doing the 3.8 manny swap and transcooler. Next month tune from cody.
Anybody remember what issues there is with running a 75 manny with a 72 tb?
Discussion starter · #26 ·
#9 fuse blown
August 15th or 16th ima have the 6g75 manni installed:eek3::eek3:. Currently the #9 fuse is blown:noplease:. Some fixes on here are double check the extended wires, make sure they are not damaged / shorted. On the facebook group page i describe them my problem and their fix was a distributor. "Was driving about 70 mph then i notice car cut off" It did rain very bad the previous day, I have a vented hood, I have long tube headers, and a couple days prior to this i had the alternator changed. I'm going to check extended wires first. My question besides o2 wires(probable cause) cps & distributor, has anything else from the list of 17 accessories the #9 fuse power cause a car to die will driving?
Discussion starter · #27 · (Edited)
Replaced distributor cap and rotor, but it ended up being a short in the o2 wire for bank one sensor one, vacuum leak, and over heating problem. Car is back running after being down since the 2nd of August. Figured i'd start only running shell gas and super mobile oil.
Looks good. Only thing I can see in that photo is the missing side skirt end cap.
Discussion starter · #40 ·
Thanks everybody, I basically got bored 2 days ago and painted my wheels a metallic black, then i thought you rarely see yellow brembos or bbk unless its on Porsche, Lamborghini, Ferrari. Can't wait to i get the lettering back on it.
speed bump got me for 3 or the 4 lbs
