Hey guys , I am new to the dsm world! Have a 2000 eclipse GT, need idea on some visual mods. This is the list of what I have done to it!
Okay. Here it goes Both head gaskets with heads plained down for even surface, intake manifold gasket, throttle body gasket, egr valve gasket, 1 o2 sensor, thermostat,injector o-rings, exhaust manifold gaskets, headers, wrapped with head warp and siliconed, new 2.25" exhaust piping all the way back with magma flow high flow cat. K&N air filter, new timing belt, water pump, power steering tensioner, power steering belt, serpentine belt, new heater core, new coolant hose bracket behind the block, new clutch, throw out bearing, flywheel has be plained down to ensure even surface, new aluminum oversized radiator, I put royal purple transmission fluid. I've had 3 oil changes done every like 1000 miles. Also new oil pan and gasket
Suspension new tie rods, front and rear sway bar links, new drilled and slotted brakes and pads, 1 new drivers side axle, drivers side ball joint. And new Ngk spark plugs and racing plug wires 10.5mm
