Aftermarket alarm install (wire locations)
8.4K views 14 replies 5 participants last post by  quick92rs
I have an alarm system with keyless entry that I want to install, but the problem is locating all the required wires. I read the sticky thread that MECP posted, but the pictures are not showing up... can anyone else see them? Anyway, I spent all last night, and all day today, searching on here and on google where exactly the wires are located on the 2000 Eclipse GT but I keep finding different results.
For example, after searching on here I found that the ignition wire at the12volt.com is black/red, on family.raminal.com it is blue/red and on other user posts it is green. Same for other wires.
Basically I need to know where the following 7 wires are:
Ignition
Parking Light
Door Trigger +
Door Trigger -
Horn Out
Lock Out
Unlock Out
(see pic below)
I'll do some testing with a meter tomorrow, but please give me some replies (or pics?) as soon as possible because I will start working on it within 10 hours. Thanks.
Here is the wiring diagram that came with the alarm:
Thanks. Looks like all of those match the wire colors on family.raminal.com as someone posted in another thread (MECP I believe).
I used this:
Eclipse 00-02 Manual
Lock Out - no idea what is this ???????
Unlock Out - no idea what is this ???????
Well I guess I need Lock/Unlock Out for the keyless entry.
Plus, if someone prys the door open, or unlocks it from the inside (with the window down) it's supposed to trigger the alarm.
Great, thanks man. And thanks for putting up those pics in the sticky thread... those helped a lot. I think I've located all the wires using a meter, now comes the fun part of installing it.
And to answer your other question, I do want both alarm and keyless entry so that I dont have to carry two key fob's around and unlock/lock both of them when approaching/leaving the car.
#10 ·
I'm getting a security system soon and don't want to get ripped off at an audio install place paying $300 to install. I'm just worried about tapping into all the correct wires. Let me know how your install goes!
