Not too long ago I started the 6G75 MIVEC swap into the 3G, originally done by silverside.
Unfortunately the MIVEC has different pistons from the normal 6G75 and holy shit, nobody but the manufactures make them, and buying from the manufactures is ungodly insane priced. it would be worth the extra $$ to contact Rossracing and make a custom set.
After 10 days of researching for cheap ass solutions, this is the results.
Getting pistons for the 06-08 MIVEC can only be done 3 ways.
1. Rossracing can make you an aftermarket set for around $1000
2. You can order from the manufactures and pay about $475
3. You can just use normal 6G75 pistons and lose some compression ratio.
What about rings? Fortunately there are more ways to get rings for the MIVEC your options are.
1. The manufactures for about $55 per piston.
2. Ross racing for who know how much.
3. Normal 6G75 rings will fit on the MIVEC pistons, an entire set should run about $90.
If you are not sure what rings and pistons will fit, go to Workshop manuals.com
This site is awesome, they have specs on everypart from every make and model. This makes its easy to compare part tolerances and use parts from a different vehicle.
I bought rings from a 2006 Endeavor from RockAuto.com which can get parts many stores cannot.
Take aways from this:
1. RockAuto.com can order parts many stoes cannot.
2. Workshop Manuals.com is a fantastic resource.
3. Dealers suck.
3. Dealers suck.
