Good afternoon everyone, I'm new here but I've got this fuel pump issue on my 2003 GTS and I cannot figure out where the issue is.
To go over everything I've done so far; I've replaced the fuel pump, the fuse and both fuel pump relays, as well as check for pressure in the line (there is none ) and check for the sound of the pump priming (there is also none). I believe this means I have to start checking wiring harnesses and pull out diagrams and schematics but before that happens I wanted to check and see if there was anything I was missing...? Thoughts?
