i have recently done a motor swap. everything went great except the car now seems to overheat.
remedies:
new water pump
new thermostat
radiator is good
hoses are good
coolant level is good
fans kick in fine
-nothing has worked
the car still overheats ......the top hose gets hot while the lower one stays cold. that is why initially i thought it was the thermostat but i have replaced the thermostat and it still overheats (lower hose still stays cold)
also there is no heat even when the car is overheating
can anybody shed some light on this??
remedies:
new water pump
new thermostat
radiator is good
hoses are good
fans kick in fine
-nothing has worked
