Any chance someone could post a pic of this? I just used a rubber mallet and a 2x4 and my cover didn't budge. All I managed to do was dent the cover a tad bit. I tried banging the the mallet on the 2x4 with the 24 placed on the front/bottom, both sides, and even from the back/top.
I removed the 6 cover bolts (which I found were only HAND tightened.. I could still tighten them more with my hand....) front timing belt cover, both hoses, front spark plugs, and the throttle cable bolt. There is nothing else to remove! Does it help to start with warm/hot engine or what? The only other thing I can think of to try is to "pry" it off using a tiny screwdriver but obviously that will end with a bent cover that will no longer seal. HELP!!! Thanks in advance.
Also, when there is black "goop" on the spark plug tubes that is just old oil and means the tube seals need replacing, correct? Just trying to confirm that I don't need to put any goop on the tubes before reinserting them (there is very little goop). Thanks.
