Well I had a extra set of stock headlights and decided to retro fit some projectors into them. No halo, ccfl, audi led style were involved with this project because i hate that look and wanted a pure OEM look with better lighting. So heres the list FX-R Bixenon projectors, GTI shroud, D2 6k bulbs, Amp to D2 harness, xentec ballast, custom relay harness.
If anybody else wants to do a retrofit projector mod. Use the next smallest projector to the FX-R ones. The FX-R's are huge and you will cut the hell out of your reflector. Big thanks to Scarr and Ken for helping me out along with install. These guys were a big help.
Chronological order of the process
All the parts
Projector compared to the reflector
Housing of the projectors. To the left is before cutting it and to the right is the one i modded to fit in the reflector
Housing fitted into the reflector
Projector and shroud fitted into the reflector
Back of the reflector. You can get a good idea of how much i cut to fit these in
Spray painting the reflector. You can see where i drilled holes to hold the projector as well
One final test fit before i sealed them
And installed
Ill get night pics tonight
All the parts
And installed
