We bought this 2003 Eclipse GTS (V6) a couple of weeks ago. The previous owner installed a new fuel pump when the orignal died. That pump was loud so he replaced it again. He told us the gauge does not work properly and he had not gotten around to taking it apart again.
I removed the fuel pump and tested the float at the plug with a multimeter. The ohm readings are correct according to the FSM. I reinstalled the pump and it will read full when filled up, but stops around 3/4 of a tank and doesn't move any further down.
He gave me the noisy pump. I installed it and it doesn't work correctly either. (And it is very loud).
I removed the noisy pump and connected the harness with it out. I moved the float all the way down and the gauge went to E. I moved the float about half, half a tank. I moved the float all the way up, F. Did the same for the other pump, same results.
I must be installing the pump incorrectly. I ran my hands around inside the tank to see if there was something for the float to catch on, but it felt normal (I guess). When installing the pump, I align the triangle on the driver's side pointing to the driver's side. 13C-10 in the FSM shows a mating mark on the chassis, but I don't see one. I only see the one on the pump.
Any help is appreciated. Thanks.
