So I bring my car to a tune shop in NJ, and after an hour or two after getting on the dyno, my tuner tells me that he's logging ridiculous amounts of knock after 10psi, like upwards of 20.
I have a 2002 RS Turbo (440CC injectors, 16g Evo 3, Evo Fuel Pump, Evo 8 Ecu flashed by FlashBlueRS)
I've been searching and reading that the knock sensor PIN on our STOCK ecu is PIN 90, and that on the Evo 8, it's pin 78. (Could someone verify this as well? I saw the Ecu Thread on dual ecus and it does say pin 90 is our knock sensor, but my tuner said he looked on his computer and the software said that it was the same pin as the Evo's??)
Now, if indeed this is true, why would it be giving me crazy knock only AFTER 10psi? If its getting the wrong signal, shouldn't it throw a code and also run like crap? Also, if I switch these pins around, as well as any other pins, it should be okay to tune, given that everything else is okay?
Thanks for any help you guys provide. Much appreciated!
