4g64 4 cylinder egr valve problom
1 reading
9.1K views 11 replies 4 participants last post by  NAPALM
My car will not stay on and is running really crappy. It is throwing an EGR valve code. I know what an egr vale is and how it works, there is only one problom I cant find it anywere on the 4cyl engine, and ther is nothing that connects from the header to an egr valve. I have seen plenty of post but only on the v6.Even I know wher it is on the v6. If some one could help me I would appriciate it ...............
#2 ·
is 2001 a fedspec? i dont think ive seen a fedspec 4g64 with egr, i did my friends exhaust from the head to the bumper and there was no hookup.
well then im not sure, the best thing you can do is look at your intake manifold for a vac line with a white stripe, that *should* take you to the EGR.
#5 ·
GUys; the EGR on teh 3G is leet.
There is no pipe coming from the manifold to the egr valve. Exhaust gas passes through a small port that is cast into the cylidner head on cylinder #4.
The EGR valve itself is buried on the back side of the intake and is a real cocksucker to get at if the intake is on the car.
Ill try to upload a pic so you can see.
thanks i really need that pic. I think I know what your talking about now because we recently took off my head to put the RPW stage 2 cam and valve springs, and I saw that port in the head and intake manifold gasket. So it should be on the drivers side........
