ABS a hindrance?
7.5K views 142 replies 23 participants last post by  TIMMAAHH
I recall many people pulling their ABS fuse because it ties in hand in hand with their traction control, mainly at the track. Well, a few days ago I did just that, just to see if there was any real noticaeable difference. I was looking for a traction difference but didnt find it too noticeable. But to my surprise the big difference I felt was in my brakes, they are WAY stiffer and bite a lot harder.
Ive left the ABS disabled for a few days just to see its its mainly a placebo. But no. They definately bite a whole lot harder. I havent even locked them up at all, even while doing a significantly hard braking sequence. So my question is, is ABS really a hinderence? I know they dont go into effect until you lock up your wheels, but why the stiffer pedal and harder bite since I disabled them? Am I playing with fire here?
#2 ·
I've had a 2001 with ABS and I have a 2002 without. It feels like I have more stopping power now, but I can lock them up fairly easily. I'd recommend leaving the ABS alone though. If I could have ABS back I would simply because it is better for panic situations and slippery surfaces. The times when you need it, it will stop you faster.
My .02
ABS doesn't help a car stop faster on dry pavement.
Very little people know the real purpose of ABS. It is there to allow you to steer to avoid an accident.
In a panic stop a person slams on the brake pedal very quickly and crosses the threshhold of their brakes capabilites. The brakes lock, the tires DON'T spin. If the tires aren't turning/spinning the car can't steer, you could turn the steering wheel lock to lock when your brakes are locked and your not gonna be turning ANYWHERE. Just like when your sitting still at ZERO m.p.h., if you turn the steering wheel the car may shimmy a tiny bit but the car won't turn anywhere because the wheels aren't spinning.
#10 ·
kabob said:
ABS still significantly reduces braking distance compared with a similar vehicle with no ABS.
No, it doesn't.
Take a car with ABS, put it on a straight piece of road, get up to 40 miles per hour and at one set of cones lock up the brakes to engage the ABS system, measure the distance.
Do it again with ABS engaged.
Now perform that exact same sequence of events with the ABS disengaged.
Get a grasp of the vehicles lock-up threshhold point and try to avoid lock-up AT ALL COSTS!!!!!!
Without lock-up, measure the stopping distances. THEY WILL BE SHORTER.
I state this with the knowledge and experience from driving Reynard Dodge's, Formula Dodge RT/2000, Formula Dodge open wheel race cars as well as several street cars in open track simulations.
well the car was an older taurus...older meaning relative to now, ithink it was like a 98 or something...and the roads were a little slick, but the car was still in good shape...only like 30k miles on it like 14 months...and i locked up the brakes when i stomped em too hard to stop when some dumbass cut me off :dunno: it happened in several other situations too, so i just kind of assumed...thats the only abs car ive ever driven...ive driven a few minivans with it :lol: but people dont pull out in front of you as much when they think they will be crushed....
Phil said:
IT'S THE ONLY BENEFIT!!!!!!!!!!! :rant:
Au contraire :)
http://auto.howstuffworks.com/anti-lock-brake1.htm
The theory behind anti-lock brakes is simple. A skidding wheel (where the tire contact patch is sliding relative to the road) has less traction than a non-skidding wheel. If you have been stuck on ice, you know that if your wheels are spinning you have no traction. This is because the contact patch is sliding relative to the ice (see Brakes: How Friction Works for more). By keeping the wheels from skidding while you slow down, anti-lock brakes benefit you in two ways: You'll stop faster, and you'll be able to steer while you stop.
Phil said:
No, it doesn't.
All that really depends on the ABS threshold, no? If you have a car with a "safe" ABS system that starts modulating long before the tires actually start to lose traction, then yes, not having a system such as that (in which you can brake closer to the threshold before impending lockup) would result in shorter stopping distances.
#17 ·
But the tests would be done with ABS disabled.
I have never heard of such an ABS system. If an ABS system were to begin modulating the actuation of the brakes before traction is lost, traction will be lost even easier, correct?.....
#18 ·
Phil said:
Yes, that states exactly what I said "The ability to steer in a panic braking situation is the only benefit."
No, it doesn't. Did you read what I quoted and bolded?
I don't know where you're going with this...
The whole point of modulating the brakes in the first place is to prevent lock-up which would cause a corresponding loss of traction with your tires. So no, you're not going to lose traction faster or more easily. And different vehicles have varying aggressiveness with their ABS systems. My old Integra Type R had a lighter, less intrusive ABS system than the GSR model, for instance.
#19 ·
all i know is that my abs is primitive, noisy, shakes the car, and keeps me from sliding around in wet conditions only. ive never had it engage on dry road ever. it only engages AFTER the wheel locks, so on my car panic stop in the rain is like lock spin lock spin lock spin, and it sucks, im better off not engaging it i feel like some times
#21 ·
eslai said:
Get better tires.
ya i know, theyre balder then phil :p im prolly gona get some yokohama avid h4s, they seem to be good tires, i really havent read anything bad about them besides being a lil mushy initially on a sharp turn, but shit i got soo much body roll i dont think id notice a lil mush on the tires
#23 ·
it sounded like kabob was confusing TCS and ABS a lil bit, as some TCS's will apply braking to invidual wheels in order to keep the car from spinning or sliding. that may have been the "safe abs" he was referring to? as far as i know no abs system engages until wheel lock has occurred or as it is occuring
Different cars will engage ABS sooner before impending lockup than others, similar to TC systems as you mention. In the example I gave above, I could brake much harder and lock up my brakes if my tires were bald with my ITR but on a GSR, the ABS brakes would start modulating before it comes that close to lock up.
ya, like i said some cars engage right on the lock up threshold, some do it after lock up. my car doesnt engage unless its hard panic stop and its wet. i really tried hard to get it to engage on dry road today, i put the pedal to floor at 45 on an empty road and i left 2 skids of rubber about 5 feet long and brought my car down to 5mph and took off and tried it again to a dead stop from 30. no abs engaging because even tho my wheels slowed down enough to leave rubber they didnt stop spinning. had it been wet the car would have slid with abs modulating like crazy massaging my foot and shaking the car. i remember one time that ABS actually saved my life, my dad was following a van in the rain at about 45 on new black top ( nice and slick) they suddenly stopped very very hard and my dad slammed the brakes on his 88 taurus 3.8 sedan, but we coudltn stop fast enough so with the brakes still on he threw the wheel over and we slid pas them and ended up backwards on the shoulder. that was scary as hell, but since the wheels didnt lock he was able to steer out of the way of the accident
