When I bought the car, I tore it down to the ground so I wouldn't have to nickel and dime it. That would keep her car out of the garage and give me time to work on my car.
With everything done, gaskets, rotor, cap, plugs, wires, sensors etc (even had a built trans w/custom valvebody installed and they couldnt be 100% sure where the leak was originating from) it still leaks
So anyone with a GTS manifold knows how much it sucks moving all the crap off the manifold and fitting your arm and hands behind the mani for the egr bolts
well over the weekend I re-did it and due to the position of the rear valve cover, its hard to see if the leak was originating from there or not.
So cleaned it up agian, new gasket, 30 in lbs etc
2 cans of brake cleaner everything is bone dry from under the car.
3 days later, wife brings it back home, its still dripping on my driveway :dunno:
look under it again, of course everything is wet again but this gets interesting.
I see a drop of oil forming under the rotor cap
How could oil move from driver side of the car, run across the motor and leak down by the belts and oil pan ? maybe the motor mount really is shot and is sagging
can these distributors leak oil?
