It's pretty well known that I have a Sporttronic transmission, but today I took my first step in the swap by pulling the parts I need out of a donor car (neffarious).
Joe and I attacked his car today pulling the engine & tranny. After this experience, replacing a clutch should not be too much of an issue.
Neffarious' car, prepared everything to pull it out as you see here...
Pulling the axles out is cake, they slide right out.
Removed the clutch switch and the gear shift cables.
6G72 Powah
Massive drivetrain hanging in the air :twothumb:
Empty engine bay, with a big pool of powersteering fluid leaking from the band clamp.
See right through the differential
Loaded the 5spd tranny up into Sporty :naughty:
The next pain in the ass is going to be removing all the cables from the cabin including the clutch pedal.
6G72 Powah
