Hey guys,
If you have been following my mebers ride thread you know i have been in the middle of the 3.8L swap.
Well its in, it was running, now i have a few major problems. Any help would be great.
motor had 50K miles
Diamante upper and lower intake
Diamante TB
Diamante Fuel rails.
New spark plugs/tube seals/VC Gasket
I got the motor running, took the car around the block. Used Cody's base tune for the 3.8. Not going to lie, the car had no get up and go. Code poped (p0300) Random/mult misfire. Got it back to the house and started to poke around and found nothing strange. Checked to see if all the plug wires were seated (check) made sure there was spark (check). There were no other codes thrown or pending. I put everything back together and fired her up again. Hard start and would not hold idle. Tried and tried again but nothing. Took everything off again, checked it again. I took the cap off the distriibuter and prongs were a little white with build up but it wiped off, checked the rotor and it looked fine too. Put everything back together, and still wont hold idle.
Any ideas guys? both on the misfire and the idle issue?
motor had 50K miles
Diamante TB
